Hello, is it possible to configure a plugin “duplication” to search between different bases ? Or maybe there is other option to automatically delete data that is duplicated in a different base ?
This is not possible with the deduplication plugin. You have to use either:
- common dataset
- python scripting
- n8n
Best regards
Thank you for your answer, could you describe the simpliest way to do this ?
