Drop down menu in webforms
I would like to change a dropdown menu appearing in a webform as it offers incorrect options (options that are not in the column and should not be there). I can’t find where to do this… Can you help please?
Thanks!
Please double check the defined options in the select column in question.
I have NEVER seen a form offering options that are not available in the list of options.
Thank you, I thought the defined options was based on what is actually in the columns. I modified the defined options at the top of the column and it indeed solved the problem. Thanks a lot.
