I have 1 row in a table linked to 8 rows in another table, and then using the Lookup function to display the values from a specific column:
But when the values are all the same, (which is common in my use case), I have needless repetition. Is it possible to display the value just once, and remove the duplicates?
It’s been 2 years but the problem has never been fixed. Maybe now there is a possibility to fix it?
The Link formula column shows the correct values.
As this request is for a very specific use case that does not affect the public, it has not been worked on.
Perhaps you can use a formula to output the value only once, so please take a look.
