Enforce 2FA for all users
We want to activate 2FA for all users (Enterprise Edition). I find the setting to enable it and to enforce it on a user basis. But is it possible to enforce 2FA for all users (or department) instead individuell for every user?
And a second question. During 2FA login I found a “remeber my PC for 90 days” checkbox. Can I reduce the days or deactivate the checkbox? Or is this part of the 2FA API?
Hello Tom,
you can set
ENABLE_FORCE_2FA_TO_ALL_USERS = True
in dtable_web_settings.py to achieve the desired goal.
(for more, see here: https://manual.seatable.io/config/dtable_web_settings/#user-management-options)
The 90days cannot be configured with a config file parameter.
