Hello, I am using seatable daily and suddenly after i restart my server, i am unable to start the docker and it give me the following error
ben@ben:/opt/seatable$ sudo docker-compose up -d
seatable-memcached is up-to-date
seatable-mysql is up-to-date
seatable-redis is up-to-date
Starting seatable ...
ERROR: for seatable a bytes-like object is required, not 'str'
File "/usr/lib/python3/dist-packages/docker/api/client.py", line 261, in _raise_for_status
response.raise_for_status()
File "/usr/lib/python3/dist-packages/requests/models.py", line 940, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 500 Server Error: Internal Server Error for url: http+docker://localhost/v1.22/containers/edcc55468a3808911991976080d8c00b4a8bf96e6c6da8e2fdaf1cf95a934a16/start
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/compose/service.py", line 625, in start_container
container.start()
File "/usr/lib/python3/dist-packages/compose/container.py", line 241, in start
return self.client.start(self.id, **options)
File "/usr/lib/python3/dist-packages/docker/utils/decorators.py", line 19, in wrapped
return f(self, resource_id, *args, **kwargs)
File "/usr/lib/python3/dist-packages/docker/api/container.py", line 1095, in start
self._raise_for_status(res)
File "/usr/lib/python3/dist-packages/docker/api/client.py", line 263, in _raise_for_status
raise create_api_error_from_http_exception(e)
File "/usr/lib/python3/dist-packages/docker/errors.py", line 31, in create_api_error_from_http_exception
raise cls(e, response=response, explanation=explanation)
docker.errors.APIError: 500 Server Error: Internal Server Error ("b'driver failed programming external connectivity on endpoint seatable (bf586cdcff2007f4bec804cd55dca2e5f1842bfc500afd1cb5886daaf1c8c5dd): Error starting userland proxy: listen tcp4 0.0.0.0:80: bind: address already in use'")
File "/usr/bin/docker-compose", line 11, in <module>
load_entry_point('docker-compose==1.25.0', 'console_scripts', 'docker-compose')()
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 72, in main
command()
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 128, in perform_command
handler(command, command_options)
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 1107, in up
to_attach = up(False)
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 1088, in up
return self.project.up(
File "/usr/lib/python3/dist-packages/compose/project.py", line 565, in up
results, errors = parallel.parallel_execute(
File "/usr/lib/python3/dist-packages/compose/parallel.py", line 112, in parallel_execute
raise error_to_reraise
File "/usr/lib/python3/dist-packages/compose/parallel.py", line 210, in producer
result = func(obj)
File "/usr/lib/python3/dist-packages/compose/project.py", line 548, in do
return service.execute_convergence_plan(
File "/usr/lib/python3/dist-packages/compose/service.py", line 567, in execute_convergence_plan
return self._execute_convergence_start(
File "/usr/lib/python3/dist-packages/compose/service.py", line 506, in _execute_convergence_start
_, errors = parallel_execute(
result = func(obj)
File "/usr/lib/python3/dist-packages/compose/service.py", line 508, in <lambda>
lambda c: self.start_container_if_stopped(c, attach_logs=not detached, quiet=True),
File "/usr/lib/python3/dist-packages/compose/service.py", line 620, in start_container_if_stopped
return self.start_container(container)
File "/usr/lib/python3/dist-packages/compose/service.py", line 627, in start_container
if "driver failed programming external connectivity" in ex.explanation:
TypeError: a bytes-like object is required, not 'str'
may i know what is happening to my system?
I am using seatable self host 2.6
