I’m trying to use the JavaScript API, following the steps described here.
I’m using Node; I installed the seatable-api
package using npm (I hope this is the right one):
npm i seatable-api
When I run the following code:
import { Base } from "seatable-api";
I get this error:
ReferenceError: regeneratorRuntime is not defined
What should I do?
(In the meantime, I’m using the savvytec-seatable
package, which seems less comprehensive but works for me.)
