Hello everyone,
I am experiencing a bug in Seatable 1.6.0.
When I open admin settings and then click on “Statistic” I get a popup saying “Events not enabled.” and the screen keeps loading.
The browser console has the following issue:
domain.com/api/v2.1/admin/statistics/active-users/?start=2021-01-10 00:00:00&end=2021-01-16 00:00:00
returns an error 400.
dtable_web.log has the following:
2021-01-16 16:11:01,885 [ERROR] seahub.api2.endpoints.admin.statistics:136 get Invalid URL ‘/admin/statistics/scripts-running/by-user/’: No schema supplied. Perhaps you meant http:///admin/statistics/scripts-running/by-user/?
Is this a known bug or is it just me?
Thank you
nginx reverse proxy config:
server { server_name domain.com; proxy_set_header X-Real-IP $remote_addr; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_redirect off; proxy_set_header Host $http_host; location / { proxy_pass http://127.0.0.1:8080; proxy_set_header Host $host; proxy_set_header X-Real-IP $remote_addr; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_set_header X-Forwarded-Host $server_name; proxy_read_timeout 1200s; # used for view/edit office file via Office Online Server #client_max_body_size 0; } listen 443 ssl; # managed by Certbot ssl_certificate /etc/letsencrypt/live/domain.com/fullchain.pem; # managed by Certbot ssl_certificate_key /etc/letsencrypt/live/domain.com/privkey.pem; # managed by Certbot include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
