Hi everyone,
I am noticing a bug on version 4.2.
- I have a base.
- I click “Export View to Excel”.
- A small popup window appears with the loading animation
- It disappears and nothing happens.
I tried different browsers and it’s the same. I upgraded to 4.2.1 and still the same.
It was working before I upgraded to 4.2.
I see the following error on dtable-events
[2023-12-19 17:42:07,060] task_manager.py[line:357] [INFO] Run task: 65d129ab-3b47-41fe-ba9e-7b5927735c20 <function convert_view_to_execl at 0x7f996b714a60>
[2023-12-19 17:42:07,071] __init__.py[line:912] [ERROR] get nicknames. ERROR: failed to get related users ee67013a-dc86-48c2-b498-27e61f96eb7f <html>
<head><title>403 Forbidden</title></head>
<body>
<center><h1>403 Forbidden</h1></center>
<hr><center>nginx</center>
</body>
</html>
[2023-12-19 17:42:07,072] task_manager.py[line:365] [INFO] Run task success: 65d129ab-3b47-41fe-ba9e-7b5927735c20 <function convert_view_to_execl at 0x7f996b714a60> cost 0s
dtable-web:
2023-12-19 17:44:02,256 [WARNING] django.request:224 log_response Not Found: /api/v2.1/workspace/4/dtable/BASE_NAME/export-excel/
This must be a bug or maybe you introduced a change which broke my setup.
I have nginx running in front of the usual seatable docker-compose.yml file.
docker-compose.yml
version: '2.0'
services:
db:
image: mariadb:10.4
restart: unless-stopped
environment:
- MYSQL_ROOT_PASSWORD=REMOVED
- MYSQL_LOG_CONSOLE=true
volumes:
- /app/seatable/mysql-data:/var/lib/mysql
networks:
- seatable-net
healthcheck:
test: ["CMD", "mysqladmin" ,"ping", "-h", "localhost", "-u", "root", "-p$${MYSQL_ROOT_PASSWORD}"]
timeout: 20s
retries: 10
interval: 5s
start_period: 20s
memcached:
image: memcached:1.5.6
entrypoint: memcached -m 256
networks:
- seatable-net
redis:
image: redis:5.0.7
networks:
- seatable-net
healthcheck:
test: [ "CMD", "redis-cli", "--raw", "incr", "ping" ]
timeout: 20s
retries: 10
interval: 5s
start_period: 20s
seatable:
image: seatable/seatable-developer:4.2.1
ports:
- "127.0.0.1:8080:80"
volumes:
- /app/seatable/seatable-data:/shared
environment:
- DB_HOST=db
- DB_ROOT_PASSWD=REMOVED
- SEATABLE_SERVER_LETSENCRYPT=False
- TIME_ZONE=Europe/Berlin
depends_on:
- db
- memcached
- redis
networks:
- seatable-net
healthcheck:
test: [ "CMD", "curl", "--fail", "http://localhost/"]
timeout: 20s
retries: 10
interval: 5s
start_period: 20s
networks:
seatable-net:
nginx.conf
server
server_name domain.com;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_redirect off;
proxy_set_header Host $http_host;
location / {
if ($allowed_country = no) {
return 403;
proxy_pass http://127.0.0.1:8080;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Host $server_name;
proxy_read_timeout 1200s;
# WebSocket support
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
client_max_body_size 100M;
listen 443 ssl http2; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/domain.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/domain.com/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
access_log /var/log/nginx/domain.com.access.log;
error_log /var/log/nginx/domain.com.error.log;
Is this a verified bug? If not, any idea what the problem might be?
Thanks in advance
