Formula not working
I have following formula:
IF(
    OR(
        {Austritt-Datum} <= today(),
        {Verstorben} <= today()
    "Nein",
    "Ja"
For one data entry {Austritt-Datum} is 31.12.2022, so in the past. The output of the above formula is still “Ja” , but should be “Nein”.
Can someone help out?
Works well here:
This is my formula:
Thanks! I found the issue. When the field “Austritt-Datum” is empty, then the formula returns “Ja” even though the field “Verstorben” is in the past. So both fields need to have an input value for it to work.
Is there a way to fix this?
You can encapsulate multiple ifs together:
if(a = a, "same value", if(a = b, "another value", "anything else"))
I am sure you will find a solution.
