Having problems importing CSVs
I’m having problems importing from CSVs. When creating a table from a CSV all the fields are shown as text even when there are dates and numbers. Is it possible to tell Seatable the format type of each column when importing?
Secondly when importing updates a new record is being created rather than existing records being updated. How do I fix it?
Otherwise fairly impressed with Seatable.
Please see section “Notes on CSV import” at Import data to SeaTable using CSV - SeaTable
Two avenues to deal with this limitation:
  • Save the CSV as XLSX file before importing into SeaTable
  • Modify the column types after the import
Use "Update data from xlsx or csv file.
Glad to hear!
