I noticed that if I hide a column ( field) in grid view and I open the card of a record, the hidden columns or field doesn’t show in the card details .
What could be the problem?
Also, there’s no field( column type)for phone.
Then, the email field, in my opinion, should be designed such that if one clicks on email, one can directly send email to the contact.
I think I understand your issue. When you open the row details (you call it card), you do not see the hidden columns.
This is the designed behavior. In the row details, you only see the columns that you haven’t hidden. If you want to see more columns, create another view and unhide the columns you want to see.
But it can be designed such that when a column is hidden nd one opens the details view of that record, the hidden column will still be hidden but with a button that shows an option to see hidden fields while a card is opened.
When I discovered SeaTable I found out it is a very new application but it became better and better over the last months. The team and @rdb, are always open to ideas and bugs that we users report.
@fsa already said the text column can be used to store any information and it has a good validation feature. With the button column you could run a javascript or python script that can send SMS, as long as you have an account with an appropriate provider. Alternatively you could connect to a automation service like make or n8n for such requirement.
