Yaenz
July 13, 2022, 9:23am
#1
Hi you SeaTablers,
I have the following problem. I do a lookup on the times table and get individual records (marked in red). I let the times be displayed (green). How can I summarize the individual times to a total (blue)?
Thanks for your help Yaenz
rdb
July 13, 2022, 9:57am
#2
Please use a roll-up function in the link formula column. Summary method should be sum.
cdb
July 13, 2022, 10:18am
#3
Hey Yaenz,
here is how I would do this:
save the time in a duration column and not a text or value column !!!
then use the link formular with the rollup to summarize the time.
with this setup you get this result.
Probably you have to change the format of the column
Best regards
Yaenz
July 13, 2022, 1:40pm
#4
Ohhhh Christoph,
Thanks a lot, this finally works fine.
Thanks Jens
system
closed
July 15, 2022, 1:40pm
#5
