Do triggered automations only work in one row or is there any chance to use it for all rows?
For example there are ten rows in which the single selection field has to be changed from “In progress” to “Done”. I want some kind of selection or button, which automatically changes all ten rows at once. My automations only work for one row at a time.
The real use case is the following “Application for vacation”.
The user has to manually input every single day, he wants to take off, so this might be 5 days for Monday to Friday, which means, this will create 5 rows. As soon as he clicks onto the Button for the first row, he requests approval from his supervisor, also each single day will automatically be checked if this day is one of his regular off days, as well as a national bank holiday. There are currently about 120 columns checking if the day might be an offday or a national bank holiday.
It would be perfect, if the first button (for the first day of his vacation) would also activate all the other buttons, so he does not have to click 5 buttons.
You now, may understand why, your solutions are not correct in this case.
If you create a view for each employee and filter on the appropriate vacation, you can use the search and replace function to change the status of the desired entries.
For easier management of leave requests, feel free to check out our template.
I will check and see what I can do. The basic idea was to automate the whole process.
In all fairness, your template is not useable in a business environment, as it still needs a lot of manual work, e.g. for calculating of the national bank holidays and so on.
