I have a formula which contains positive and negative numbers, as well as " #N/A " as result. I want to create a additional formular as an ifs, which says
Seatable uses the first rows to determine the result type. In your case, Seatable probably recognises the formula results as numbers. If the result type is number, N/A is not a valid value and hence not displayed. (In a number column, string are not shown either.)
