After import of a CSV file, I intend to get rid of some special characters in a field. The characters just need to get surpressed and I do not opt for correcting the import file, as I need a general solution.
The character strings are [""
and ""]
, also a bracket and then two "
and they can get replaced by “nothing”.
The formular that should be capable of doing this is SUBSTITUTE(SUBSTITUTE(Fieldname, "[\"\"", ""), "\"\"]", "")
. And Seatable offers an interesting result, as only the []
are eliminatet. As an illustration the field value [""-""]
results into ""-""
I already tried single quotes''
and was looking for an alternative like CHAR or CODE, which do not exist. Thank in advance for some enlightment, where I made a mistake
PS: The manual search and replace removed them without a problem.
