I’m using SeaTable EE , I have the Maps Plugin installed and I have the API key loaded in the dtable_web_settings.py file. My table has a column with Lat and Long which I believe is the format the API requires. It looks something like this:
After a enter a bunch of sample Lats and Longs, I go to Plugins > Maps and then I edit settings to have the Address Field be the field with Lat and Long.
Then I go back to the Map and nothing is there. No pins, no locations, just a blank map.
Any ideas what I am doing wrong? Is the API looking for a different location format?
