Hello everyone,
could you give info how to remove dummy data in the new template to use them?
Hello everyone,
You can select all rows in a table by clicking the box left to the first column’s name.
It removes the row but doesn’t remove the content. It’s a major issue when using the yearly calendar…
Aren’t the rows the content of the database? I don’t understand.
No, the rows are the full structure of a line.
So basically, it removes everything…
I don’t understand. Someone else?
Hi @AXN ,
As @rdb , I’m struggling to understand your problem. Can you provide the exact name of the template that causes the problem, or even better its URL to have a closer look ?
Everyone of them that I selected…
Problem #1:
Please tell me how to erase data inside a line, aka a row, without deleting the line?
If I clic on the box, left of the row: it has the option to only delete the row but not remove all data in the row as template dummy data…
Problem #2:
How do we undo/rewind a data entry or deleted action?
Problem #3:
Lots of the tutorial was only in German & had to manually add /en/ but even some had already it but was in German.
I really like the potential of this product as it is game changer as I would lose time to write this.
Hi again @AXN ,
Problem #1: you can click in the first column of your line, drop to the last column (or SHIFT + right arrow) and then DEL as in Excel for example
Problem #2: you can use CTRL+Z
Problem #3: Not sure if it’s the same problem, but looking at this post, trying again in a few days might eventually do the trick
You can also highlight all cells and then press “Delete”. Done.
But allow me this question: Why do you want to keep empty rows?
Adding to what @bennhatton said, SeaTable logs all modifications in a base. In this log, you can undo most changes.
We’ll modify our website quite a bit in the second half of the year. We realize that the auto-translation part does not work as smoothly as it should.
