How-to: SeaTable Frontend Customizing
Hey everybody,
you run your own SeaTable server and would like to give your system an individual look? Then here comes exactly the right thing for you:
https://manual.seatable.io/config/frontend_html_template_system/
In this manual entry, we will explain to you how to customize e.g., the login page of SeaTable or the emails. We will take you by the hand and explain where you can find the corresponding HTML templates and how you can customize them.
Feedback is more than welcome.
Oooooh nice :slight_smile:
Thank you for this documentation ^^
I’ve been able to customize my login page.
