I am new to Seatable and trying to create a dropdown that will select options from 1 of 4 tables depending on the choice selected previously. So imagine I have 4 different types of product, column 1 is a Single Select for which Product I am interested in. The next column is the product detail but should select the choices from a different table depending on the Product Type chosen.
I have 4 different types of product. Each product has a different table with different fields.
I want to be able to select 1 of the 4 products in another table and then depending on which product is selected, there is a second column where I pick 1 of the products in the table selected.
For example, I have the following types of car - Compact, SUV, Electric and Sedan. There is a field in a table to select 1 of those 4 car types. In the next column I can select which model, but I only want options shown that correspond to the type of car selected.
Alright, so here is the actual database which should show what I am trying to do.
This is the selection table Product for different types of Commodity. Each Product has its own Table with different characteristics.
Then, for example, I have different types of EN590 and Coal and I want to collect Inquiries of different products.
What I actually want is instead of having the columns Coal Type and EN590 Type that I have 1 column - Product Type.
What Column Type should I use for Product Type? The difficulty is that I can link tables but only 1:1. I want to have a column which allows selection from one of the Product Tables DEPENDING on the Product selected in the Inquiry Table.
in your “Inquiries” table, you have already created a link to the “Products” table with the “Product” column, so you don’t need to create an additional link for the product type. You can work with the “Link formula” column and the “Look up” function to display the relevant data.
Does that help you?
