I am trying to import data from a base query via a CSV file, about 2000 records.
There are two boolean fields in the CSV file, which are converted to the values 1 = true and 0 = false.
During import, they are treated as text fields, but this can easily be changed to a number format. I am now looking for a way to change these columns to the checkbox format. In my previous attempts, I have lost all the data in the corresponding columns. Is there a way to convert the columns so that the value 1 = checked and 0 = unchecked?
Either you create an automation with trigger event “Records meet specific conditions after modification” with filter condition Number = 1 and Automated actions on set checkbox to “checked”.
Then you insert your values in the number column and the automation takes effect.
Or you can create a periodically triggered automation with condition Number = 1 and an automated action to set the checkbox to “checked”, then manually click on run now.
This is how I would do it: Use this formula “if({source_colum}=1,True,False)” Then create a checkbox column and paste the values from the formula column into the checkbox column.
