To import from Excel to Seatable a table with a column with multiselect data separated by " / ", what should be the separator to use ?
I alreayd tried #cr or #lf special character but Seatable recognize the column as Text and when I change colum type to multiselect, it ignore separator. An idea ?
Hi Remi,
if you separate the records with a comma, you can simply paste it into a column of type “Multiple select” (via copy and paste) and it will automatically create the individual options.
Hello fsa,
This works perfectly indeed.
Thank you for the tip !
