Insert_column link_formula/lookup column_data parameter
Hi everyone,
I’m working on a new project (I hope I’ll be able to tell you more about it later) and I’m stuck on the definition of the column_data for the insert_column function in the case of a link_formula/lookup column (pretty specific indeed)…
As far as I understand it looking at the API documentation, I can pass the following parameters:
  • formula (string) required
    The formula of this column. (in my case, lookup)
  • link_column (string) required
    Name of the link column.
  • level1_linked_column (string) required
    Name of the column in the linked table to look up.
This is pretty clear, but it doesn’t seem to allow to cover the case of a “double link” : a lookup linking to a column being a lookup itself, whereas the interface allows it.
When I look at the column description/metadata for such a “double link”, I see similar but also extra parameters:
    'formula': 'lookup',
    'result_type': 'array',
    'operated_columns': ['QFy0'],
    'link_column_key': 'QFy0',
    'level1_linked_table_column_key': '9KIf',
    'level2_column_key_required': True,
    'level2_linked_table_column_key': 'A9Ab',
However, I didn’t succeed neither in passing such “level2” parameters to the API nor in finding some documentation about it (the names might be different, as for level1_linked_column and level1_linked_table_column_key for example)… Any clue ?
We check the source code and found that there is another parameters “level2_linked_column (string) Name of the column in the table linked by levlel1_liked_column to lookup” you can pass. Please refert the curl code below and try again
curl -X POST \
  'https://dev.seatable.cn/api-gateway/api/v2/dtables/uuids/columns/?table_name=Table1' \
  -H 'Authorization: Token xxxxx' \
  -H 'Content-Type: application/json' \
  -d '{
  "column_type": "link-formula",
  "column_data": {
    "formula": "lookup",
    "link_column": "Link",
    "level1_linked_column": "Link3",
    "level2_linked_column": "Name"
  "table_name": "Table1",
  "column_name": "TTTT11"
