Hello, I am trying to install Seatable Enterprise aside Seafile Pro.
I have set up Seafile Pro using the Docker Containers (the provided docker-compose.yml) with custom ports. I also got OnlyOffice installed as a separate container as well.
In front of those I have a nginx server as a reverse proxy. Which is working fine ever since.
My plan is to have Seatable accessible as a sub directory (e.g. https://cloud.example.com/seatable/
, whereas https://cloud.example.com/
is my Seafile).
So I installed Seatable like the documentation tells you to. The only thing I changed is the port, as port 80 and 443 are reserved for my reverse proxy. I changed it to port 3102.
Then I tried to configure a location /seatable {...}
block in my reverse proxy config.
But I can’t get this to work. My current state is the following:
- navigating to
shows me a broken(=no css) page saying “Sorry, but the requested page could not be found.” along with a Yes and a No button and a language selection. - navigating directly to
http://hostname:3102
shows me a working login and file overview, but creating and opening a Base redirects me to a infinite loading animation.
Can somebody please provide me with how to correctly configure the Seatable installation and my reverse proxy?
Thank you very much!
m_te
