I have a simple question which apparently doesn’t have the answer for now
Do you have any kind of installation instructions for a self-hosted version without a docker?
I would like to install SeaTable on my VPS which already have MariaDB, Redis and Memcached installed. In this kind of environment, it would be major bloat to run another instance of those services in a docker container
I would be grateful for any kind of starting directions regarding the command line installation which doesn’t require a docker
If you want to use existing MariaDB, Redis and Memcached, you can modify the docker-compose file to run SeaTable only without MariaDB, Redis and Memcached. Then modify the config files to use existing MariaDB, Redis and Memcached IP, username and password.
But it is easy to lead to error if you don’t have much experience with SeaTable server.
