While trying to display a markdown table in a JavaScript script using output.markdown()
, I noticed that the first two rows are displayed as header (with bold font-weight). See below.
Thanks for reporting the issue. We are working on it. It will be fixed with the next release.
Thanks a lot Ralf!
By the way, I discovered this error while trying to mimic the Airtable output.table()
function allowing to display arrays or objects. If it can be helpful to anyone, it can be found at https://github.com/basteks/seatable-misc/tree/main in the script output-table.js
. I also suggest integrating it directly in the JavaScript pre-defined objects on https://ideas.seatable.io/.
