Since a few weeks, my map do not display the records. The Adress field is populated and it used to work but not anymore.
Does anyone have the same issue?
Thank you
Thank you
I checked the console and I see this error :
Is it the same for everyone? Does it mean I need to pay now? Strange
“you must enable billing on the Google Cloud Project” could hardly be more explicit. If only the error message also provided a link … Oh, the error message does contain a link …
Thanks
The fact is that it works until a few weeks ago. It’s the same for other users. So I think the solution is not so simple. My database is not related to a Google account. So I can’t understand why I have to pay something with my Google account.
I checked the link of course. There isn’t any project related. So how did it works since about one year ?
If you have any idea…
Thanks
As you did not provide essential information, it is really hard to support you.
First of all, you did not mention if you use SeaTable Cloud or SeaTable Server. (I assume the latter, but why do you let us speculate? And in fact, it is totally unnecessary. When you start a new post, you are prompted to provide this information.)
I assume @Ruby_Kioube is using SeaTable Cloud. We will have a look at this.
Right @cdb
Thank you
Well done
Problem solved !
Thank you @rdb
