I have a question. I am using Seatable Enterprise Cloud Version.
Now with the data in a base I want to create graphml files… for this purpose python offers a library called pyyed. But unfortunately this library is not available.
Hi
if you don’t want to include the module in general, there might be the possibility to install the module in a special path and I will include this path in my coding? Something like
# At the beginning of your programme
import sys
sys.path.extend([all the paths of your packages inside of app-packages])
I am sorry to keep you waiting! But we have an answer: We won’t add additional packages for now. Sorry!
If you want to use additional Python libraries in your scripts, you need to run a SeaTable instance of your own. Customizing the Python runner is not very difficult. You find the how-to here.
If you don’t want to manage your own system, SeaTable Dedicated Cloud may be an option. In a dedicated server, we can make available additional libraries. Please see here for more information.
