I’m trying out SeaTable and so far, it looks very nice.
One thing I haven’t figured out yet: I’d like to create (something like) a list of people and their contact info and export it as a PDF.
I’m not looking for a simple table layout, so I was wondering if the „Page design“ plugin can generate documents with multiple pages.
Does anyone know if that’s possible, or if there’s maybe another way to achieve this?
Indeed, printing the table via a PDF printer would be easier. If the document was purely for internal use, I would probably do that.
For our customers, I’d like to produce something nicer looking however.
So how exactly should page design do to make the page look nicer? I’m just curious because page design can really do pretty much, including changing the font, size, height, width, padding, the color of your record fields, and add static text and images. Maybe we can find a solution for you?
If I understand correctly, I have two choices right now to generate a PDF:
Either I use a PDF printer and get a simple table that can run over multiple pages.
Or I use the page design plugin, and I get a nicely formatted document that can only have a single page.
What I’m looking for are multi-page documents with layout
I’m trying to replicate a document that is currently being produced manually.
We usually fit 4-5 “records” on each page, so a single record would leave most of the page empty.
Maybe I should reconsider my approach and figure out a new way to do it.
It’s not an absolutely essential issue, so I think I’ll shelve it for now.
You are welcome! And you are right - Page design can only display one record on one page. That’s a pity. But perhaps printing on a smaller size of paper and print multiple pages on one piece of “paper” could do some trick.
The requested feature is not planned. You will need to continue to use Excel or Word for this kind of job.
But, on the bright side, should not be a big problem! You can manage your data in SeaTable and benefit from the advanced feature set (e.g., link records, views, plugins, script support), but when you need to print labels, you export a dataset into XLSX and print the data via Excel.
