We are moving from airtable to seatable because of record limits, we are now using the enterprise cloud service and we are having problem with a task base, when I scroll down to the record 100ish it crashes and the page goes blank, we also conected the base via a API to a friendly front and we we try to filter via API it returns blanks.
Hope you can help me im very newbish in this area.
Hi,just wanted to let you know we found the problem, it was de “archives” column, we conected the seatable base to another front and we think someone put a crashed file or something like that, we have ereased the column and everything works fine.
Hope this helps solving if someone have the same problem.
