Hey,
Do you know a workflow in n8n that can replicate the Seatable Automation Rules to create a Link between 2 tables based on matching values in each table ?
This is basically to perform the automation rule in the background.
Hey,
Hi @PeFlam,
I currently use such a workflow, the process is pretty straight-forward:
Please not that this actually works only il the search term is unique (meaning that your row: search action will never returns more than one item)
I wanted to embed an example in this answer, but unfortunately the n8n embedding feature doesn’t seem to have n8n-nodes-seatable installed so you can’t access the nodes parameters, which is then pretty useless…
