Need help to duplicate a Make scenario from HTTP Request
Hey everyone,
I’m having a hard time solving an issue on Make/Integromat. I want to create a scenario that duplicates another scenario when ran, and since this is not a native option, I’m trying to do that by making an HTTP Request to Make.
Everything goes well when I try to GET information from a Scenario with the Request. Everything goes well when I try to create a Data Store (via POST) with the Request. But it doesn’t seem to work for duplicating scenarios.
The problem is that I can’t get the right format for property “blueprint” and property “scheduling”. Here is my JSON code for the body :
{ "teamId":"246450", "blueprint":"too_long_to_post" "scheduling": { "type": "immediately", "interval": 900 } }
And here is the Output :
Capture d’écran 2022-12-20 à 16.00.35
Even when I put the right blueprint code, I get the same error.
I really can’t get the hang of it after many tries. If someone has the solution for this please guide me :slight_smile:
Here is the API Documentation : https://www.make.com/en/api-documentation/scenarios-post
And here is a video (in french) of what it should look like, skip to 44:22 (but the dude doesn’t show the inside of the scenario) : https://www.youtube.com/watch?v=y1_Zj-DkyU0
