Hi everyone,
I recently set up a Seatable Enterprise Edition (v 4.2.11) on my laptop (Manjaro Linux 64 bits, kernel Linux 6.5.13-6) using Docker (see docker-compose bellow).
services:
db:
image: mariadb:10.11
environment:
- MYSQL_ROOT_PASSWORD=xxxxxxxxx # Root password of MySQL -- must be changed
- MYSQL_LOG_CONSOLE=true
volumes:
- /opt/seatable/mysql-data:/var/lib/mysql # Volume of MySQL (directory for persistent storage) and mount point in container -- can be changed (not advised)
networks:
- seatable-net
memcached:
image: memcached:1.5.6
entrypoint: memcached -m 256
networks:
- seatable-net
redis:
image: redis:5.0.7
networks:
- seatable-net
seatable:
image: seatable/seatable-enterprise:latest
ports:
- "80:80" # HTTP port on the Docker host and the port in the container -- must be changed if port 80 is already in use on Docker host
- "443:443" # HTTPS port on the Docker host and the port in the container -- must be changed if port 443 is already in use on Docker host
volumes:
- /opt/seatable/seatable-data:/shared # Volume of SeaTable (directory for persistent storage) and mount point in container -- can be changed (not advised)
environment:
- DB_HOST=db
- DB_ROOT_PASSWD=xxxxxxxxx # Root password of MySQL -- must be changed to the value set above
- SEATABLE_SERVER_LETSENCRYPT=True # Decision on whether or not to use Let's Encrypt for HTTPS, default is False -- must be changed to True if a Let's Encrypt SSL certificate is to be used
- SEATABLE_SERVER_HOSTNAME=localhost # Host name -- must be changed
- TIME_ZONE=Europe/Paris # Optional, default is UTC. Example: Europe/Berlin. Choices can be found here: http://en.wikipedia.org/wiki/List_of_tz_zones_by_name
depends_on:
- db
- memcached
- redis
networks:
- seatable-net
networks:
seatable-net:
I can access the Seatable interface, and I managed to run successfully the dtable-sdk example. Nevertheless, while trying to run seatable-plugin-template (or any other plugin), I get an Multiple CORS header 'Access-Control-Allow-Origin' not allowed
error conducting to a Network Error (see bellow) while accessing localhost:3000
"stack": "AxiosError@http://localhost:3000/static/js/bundle.js:100980:19\nhandleError@http://localhost:3000/static/js/bundle.js:102550:14\n",
"message": "Network Error",
"name": "AxiosError",
"code": "ERR_NETWORK",
"config": {
"transitional": {
"silentJSONParsing": true,
"forcedJSONParsing": true,
"clarifyTimeoutError": false
"adapter": [
"xhr",
"http"
"transformRequest": [
null
"transformResponse": [
null
"timeout": 0,
"xsrfCookieName": "XSRF-TOKEN",
"xsrfHeaderName": "X-XSRF-TOKEN",
"maxContentLength": -1,
"maxBodyLength": -1,
"env": {},
"headers": {
"Accept": "application/json, text/plain, */*",
"Content-Type": null,
"Authorization": "Token xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.xxxxxxxxxxxx"
"params": {
"lang": "en"
"method": "get",
"url": "http://localhost/dtable-server/dtables/xxxxxxxxxx-xxxxxxxxx-xxxxx-xxxxxxxxx-xxxxx"
"request": {}
or sometime an ERR_BAD_REQUEST
error conducting to Uncaught (in promise) TypeError: this.dtableStore is null
"stack": "AxiosError@http://localhost:3000/static/js/bundle.js:100980:19\nsettle@http://localhost:3000/static/js/bundle.js:102181:12\nonloadend@http://localhost:3000/static/js/bundle.js:102499:13\n",
"message": "Request failed with status code 404",
"code": "ERR_BAD_REQUEST",
"config": {
"transitional": {
"adapter": [
"xhr",
"http"
null
null
"timeout": 0,
"env": {},
"headers": {
"Authorization": "Token xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
"method": "get",
"url": "localhost/api/v2.1/dtable/app-access-token/"
"request": {},
"response": {
"data": "<!DOCTYPE html>\n<html lang=\"en\">\n<head>\n<meta charset=\"utf-8\">\n<title>Error</title>\n</head>\n<body>\n<pre>Cannot GET /localhost/api/v2.1/dtable/app-access-token/</pre>\n</body>\n</html>\n",
"status": 404,
"statusText": "Not Found",
"headers": {
"access-control-allow-headers": "*",
"access-control-allow-methods": "*",
"access-control-allow-origin": "*",
"connection": "keep-alive",
"content-length": "182",
"content-security-policy": "default-src 'none'",
"content-type": "text/html; charset=utf-8",
"date": "Mon, 18 Dec 2023 22:16:43 GMT",
"keep-alive": "timeout=5",
"vary": "Accept-Encoding",
"x-content-type-options": "nosniff",
"x-powered-by": "Express"
"config": {
"transitional": {
"adapter": [
"xhr",
"http"
null
null
"timeout": 0,
"env": {},
"headers": {
"Authorization": "Token xxxxxxxxxxxxxxxxxxxxxxxxxxx"
"method": "get",
"request": {}
Here is the setting.local.js
file :
export default {
// dtable api token (required)
APIToken: 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
// server URL of the dtable of the plugin (required)
server: 'localhost',
// id of the workspace with the dtable of the plugin (required, workspace must exist)
workspaceID: '1',
// name of the dtable to add the plugin to (required, dtable must exist under this name)
dtableName: 'Essai',
// default language ('en' or 'zh-cn' are common, see "src/locale/index.js" for all lang keys)
lang: 'en'
I tried lots of things for server : localhost, localhost:80, https://localhost, 127.0.0.1… but nothing worked
Do you have any idea ?
Thanks a lot and have a nice day !
