Not work with subdomain. Help
Good afternoon!
When installing on the server - by IP address - everything works.
After directing the subdomain through A record to this IP address with Seatable set - it allows to enter, but when opening any table it writes networkerror.
If you enter through the IP address and open a table, everything works. But for an IP address you can’t assign an SSL certificate. And without SSL many programs do not want to work with the installed version of Seatable.
Does anyone know how to solve this problem?
Please read the manual:
Use nip.io instead of the ip to get a valid certificate: Custom Certificates - SeaTable Admin Manual
Or use http: Force HTTP - SeaTable Admin Manual
In general: you have to update the configuration files if you change the hostname after the initial startup…
