Hey everybody,
the last days some users complained that the creation of a superuser resulted in error. Here is the command and the corresponding logs:
root@seatable:/opt/seatable# docker exec -it seatable /shared/seatable/scripts/seatable.sh superuser
File "manage.py", line 10, in <module>
execute_from_command_line(sys.argv)
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/core/management/__init__.py", line 419, in execute_from_command_line
utility.execute()
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/core/management/__init__.py", line 413, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/core/management/base.py", line 354, in run_from_argv
self.execute(*args, **cmd_options)
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/core/management/base.py", line 393, in execute
self.check()
... (i removed some error lines)
File "/usr/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/opt/seatable/seatable-server-2.7.3/dtable-web/seahub/urls.py", line 156, in <module>
from seahub.api2.endpoints.admin.sys_plugins import AdminDTableSystemPluginsView, AdminDTableSystemPluginView, \
File "/opt/seatable/seatable-server-2.7.3/dtable-web/seahub/api2/endpoints/admin/sys_plugins.py", line 32, in <module>
PLUGINS_REPO_ID = settings.PLUGINS_REPO_ID
File "/opt/seatable/seatable-server-latest/dtable-web/thirdpart/django/conf/__init__.py", line 83, in __getattr__
val = getattr(self._wrapped, name)
AttributeError: 'Settings' object has no attribute 'PLUGINS_REPO_ID'
The reason for this error is in most cases quite simple.
As described in the installation manual SeaTable requires since Version 2.5 a seatable-license.txt file. If this file is not created or added before you execute this superuser creation, then this error occurs. You get a free license for up to three users here at https://seatable.io.
So if you face this issue: stop seatable, add the license file, start seatable and create a superuser
docker exec -d seatable /shared/seatable/scripts/seatable.sh stop
nano /opt/seatable/seatable-data/seatable/seatable-license.txt
docker exec -d seatable /shared/seatable/scripts/seatable.sh start
# add an email and choose a passwort...
# Superuser created successfully.
Best regards
