I use Cloud Enterprise.
When I view a record in Page Design, everything looks good but when I create a PDF using a button, the PDF has two problems:
Numbers are rounded down to the nearest integer if the number has 00 after the comma (I use the German number format)
e.g. 841,00 € becomes 841 € -
With one template, numbers are displayed as 0 even though Page Design shows the numbers displaying correctly.
Please note: When I use the “Print” button in Page Design and save a PDF, everything looks fine. The problem only affects automatic PDF generation (that is, clicking the “PDF” button in Page Design or using a button in a column that also creates a PDF.
I have had a similar problem to this before, which @daniel.pan thankfully fixed. In this situation, the problem was that the column names were invalid (.). I have checked and this is not the case.
Column names: I have used formulas to concatenate the values from other columns into displayable text because I wanted the €-sign to display after the number.
Some of the column names use:
- ( ), e.g. “Preis-format (brutto)”
- German characters, e.g. “Übertrag”
Are these acceptable characters?
Everything was working fine until recently.
