I have a table containing details of community organisations and key contacts.
I would like to invite key contacts to check and update the information about their organisation, by sending them a form to complete.
Usually, most of the data will not need updating, so I would like the form to have all the data pre-filled from the table, and allow the respondent to correct any field that needed updating.
In an ideal world, the link would be unique for their organisation, so each respondent could only see and edit their own data.
I’ve looked at Prefill form fields via URL - SeaTable. This allows me to create a form with some pre-filled fields, but not in the way I hoped.
I also considered using the ‘View’ option, and sending them a table, but I think I would have to create as many views as there are rows in the table.
Is there a better way to do this?
Perhaps it is a feature request?
