- SeaTable Enterprise Edition Self-hosted 5.1.9
I have a table page in the universal app and i want to set a Preset filter based on a single select column. This is simply not working.
I have only two records in the table, one fitting with the filter to test it.
The filter is set to “Single Select Column” IS “The option”
With the IS ANY OF, it gives the same error message.
It happens whether there is a Preset hidden column or none.
The filter IS NONE OF with reverse condition is actually working…
