Can a link to a record be protected? by that i mean that once created, is there something to prevent you from clicking on the Del key when selecting the cell, therefore removing the link.
I will share an app to colleagues to fill in the linked columns, but i want to disable the delete option once the people i share it with have created the record in the other table. Otherwise it will get messy to find again the record as all the values are pretty similar.
Read-only is read-only. In a read-only column, edits are not allowed. This means for a link column: Links cannot be added, modified or deleted. If you want to protect links from deletion, this is the right option.
Correct. You can use an automation to lock a row once a link has been added.
Another question ? is it normal that a linked record cannot be edited in the app just like in the base ? all fields are greyed out, even if the linked column is not read-only
