I do have a problem with common datasets (self-hosted DE 3.1). I can create a dataset as expected. It also shows up under the menu “Common datasets” on the dashboard page. But whenever I try to import it into another base I get a “Internal Server Error” message without any further explanation. When I click on the dataset in the dashboard view itself a fullscreen popup appears (supposedly where the dataset should appear) only saying in red letters “Please check the network”. Any log entries I can share that would help in identifying the problem here?
Problem was solved and can be closed. I went through the detailed additional upgrade instructions in the manual again and it seems some steps along the way were missed and caused the problem.
