AkDk7
March 14, 2023, 9:46am
1
Hi.
I am using the self-hosted version 3.4.8.
The python function base.update_link throws an error.
It says:
TypeError: update_link() got an unexpected keyword argument 'table_id'
When I remove the variable assignment, it works. When I use table_id='1234'
it doesn’t.
Did something change since the last release?
If so, the docs need an update.
Regards
AkDk7
I don’t quite understand your problem.
Can you paste your code with more details?
AkDk7
March 15, 2023, 5:36am
3
Of course, I changed the following function call to not use the key-value-asignment in the parameter list to work again.
base.update_link(
buchungenZusammenfassungKey,
buchungenTableId,
zusammenfassungTableId,
curRowId,
rowLinkId
An the documentation says (Links - SeaTable Programming Manual ):
base.update_link(
link_id='r4IJ',
table_id='0000',
other_table_id='kFoO',
row_id='BXhEm9ucTNu3FjupIk7Xug',
other_rows_ids=[
'exkb56fAT66j8R0w6wD9Qg',
'DjHjwmlRRB6WgU9uPnrWeA'
When I use that call I get the following error message.
File "index.py", line 45, in <module>
rowLinkId
Thanks!
Sorry for the inconvenience, the parameter name is now changed from table_id
to table_name
to be consistent with other APIs. You can use either table name or table id for this parameter.
The document is changed accordingly.
AkDk7
March 15, 2023, 7:08am
6
AkDk7:
table_id=
Also the batch_update_link still has the table_id reference.
And other_table_id
seems to not work either.
AkDk7
March 15, 2023, 7:12am
7
What I just realized is why is it changed to table_name since it’s the id of the table. Is it now possible to put the real name of the table, which the user can define in the gui, in it?
The document changed all id to name as I checked:
Yes, you can now use the table name the user defined in the web UI.
AkDk7
March 15, 2023, 7:19am
10
This is awesome and so much easier. Great improvement!
system
Closed
March 17, 2023, 7:20am
11
