Hoping I can get some help with my self-hosted configuration that I am currently in the process of setting up. Using a VM with a port forward to http://localhost:8991 (https doesn’t work for some reason). Everything otherwise works fine, except for a couple of issues which I think might be related to API configuration. 1) Python scripts wont run. I get an error “Failed to get the script”
To be honest, you are outside the recommended scenario, and it is difficult for us to support via forum every possible use case.
My recommendation would be that you book a Virtual Server at Hetzner. This costs just 4 € per Month. You don’t Even need a domain, just use your-server-ip.nip.io as described here in the manual: Custom Certificates - SeaTable Admin Manual
This will avoid a lot of headache, and you will save hours of troubleshooting.
Could you solve your problem?
Thanks for the response. Unfortunately I am not allowed to change the domain at the moment, but will test in the future.
I have the same problem. Is there a way to narrow down the problem and find a solution?
I am sorry to hear that it is not working. I see three possible solutions:
- follow our recommendation and use a public available key, use let’s encrypt and your system will be up and running within some minutes
- understand the flow of the data between the systems and the docker container, analyse the browser console and various log entries to determine the communication problem and try to find a solution
- book our paid enterprise support, grant me access to your system via ssh and most likely I can narrow down the problem within some hours
