I tried to list all rows of my table “Server” on my Base via following Python code:
server_url = context.server_url or 'https://seatable.myweb.com/'
api_token = context.api_token or 'my_token'
base.auth()
output = base.list_rows('Server')
print(output)
As the output got printed I already noticed it was way too short to contain all of my data. When extracting all IP-Adresses and counting the lines it gave me 12 IP-Adresses, whereby the “Server” Table contains at least 100 IP-Adresses.
The same problem occurs with base.list_columns. Only a shard of the expected data gets captured.
Is this a common problem or am I using the API in a wrong way? My goal is to just receive the full data, I dont want to add or move columns at all.
Update: I managed to get full values of each Row with requesting every single row like that:
for n in range(0, 100):
try:
output = base.list_rows('Server')[n]
expect Exception:
pass
It seems this is due to connection errors with seatable . sometimes it returns “maximum 100 connections per minute”. idk if that is due to the free version limits or due to wrong settings, because my server has proven to be fast enough to handle requests in a time like this in other type of scripts already
