Hi
Currently I am doing some transformation with Python script. Unfortunately I am not able to sort the records as I need it. This is the way I get the record set:
dflow_queryset = base.filter('D.Flow', "IF-ID='" + ifId + "'", 'xsorted')
I’m using a view “xsorted” where the data is sorted as needed, but is seems that the sorting is not considered.
Is there any way to fix this.
Thank you
