Hi everyone,
Here is a little consideration/change/eventually bug I’d like to share with you:
Since v4.4, the data you get while using list_rows
function from Python returns every column of your table, even the empty ones. This differs from the JS getRows
function which returns only the non-empty columns (and, as far as I remember, from the list_rows
return of older version of SeaTable).
See bellow the result of these two functions in a table containing the following columns:
- Id (text)
- client (link to other records)
- client’s rate (link formula/lookup)
- initial cost (number)
- cost (formula)
- my client (text)
- Try (formula)
Python data :
{'Id': None, 'client': [], "client's rate": [], 'initial cost': None, 'cost': 0, 'Main': [], 'my client': None, 'Try': None, '_locked': None, '_locked_by': None, '_archived': False, '_creator': 'edfefe21cd2641d68b592b5e18a12db4@auth.local', '_ctime': '2024-05-16T14:45:41+02:00', '_last_modifier': 'edfefe21cd2641d68b592b5e18a12db4@auth.local', '_mtime': '2024-05-16T14:45:41+02:00', '_id': 'A3xiWzEtRPycjYZMAMvBrA'}
JS data :
{"_id":"A3xiWzEtRPycjYZMAMvBrA","_mtime":"2024-05-16T12:45:41.829+00:00","_ctime":"2024-05-16T12:45:41.829+00:00","cost":"€0.00"}
As you can see, Python’s list_rows
function returns None for most columns, except the link and the link-formula columns where it returns an empty array.
If, like me, you used to test the presence of a piece of data with a simple if 'my_col' in row :
(which is probably not the best practice, but used to work), be aware that your test will now always be True
You’ll have to modify your test like, for example : if 'my_col' in row and row['my_col'] is not None:
(except for the links or link-formula columns as seen before).
Where it gets tricky
The case of checkboxes is particular, and you’ll have to pay particular attention in your tests :
- a checkbox column you never checked (with a standard unchecked default value) will return
None
- a checkbox column that has been checked and then unchecked again will return…
False
A simpleif row['checkbox_col'] :
orif not row['checkbox_col'] :
depending on your needs will do the trick, but still, having two different results for the same piece of data could be a bit confusing…
Sorry, I have no time right now to test if the same happens using the API (probably). With the query
function, the behavior seems to be the same however (but I didn’t remember how it worked before v4.4).
