Python Scripts running until timeout
Hey,
I installed seatable and the python pipeline on a selfhosted server. Installation worked fine. I can access the web gui. But as soon as I try to execute a python script, even if it is only hello world, it runs infinitely. I have no clue why it happens and I would really appreciate any suggestions or tips.
Thank you for reading guys.
Did you follow this manual: Python Pipeline - SeaTable Admin Manual?
I executed the steps in the manual multiple times, I can guarantee that it works 100%. If it does not work at your side, you either have something special, or you did something different.
Do you have anything special?
  • custom certificate
  • LAN access only
  • custom configuration of python pipeline
