Hello everyone,
would it be possible to remove the colours in the single select?
Hello everyone,
If you feel comfortable with such technical level, there’s an API function that can help you : Update Single/Multiple Select Options
Here is a little Python script that you can run to remove the colours (before using it, you will have to set three variables :
my_base_name
: the name of the base (for example my_base_name = 'Table1'
)my_col_name
: the single select column name of the base (for example my_col_name = 'SingleSelect'
)my_base_uuid
: the base unique identifier (or UUID) of the base (you can find it by clicking on your base in the team admin base page)from seatable_api import Base, context
import requests
base = Base(context.api_token, context.server_url)
base.auth()
my_base_name = 'YOUR_BASE_NAME_HERE'
my_col_name = 'YOUR_SINGLE_SELECT_COLUMN_NAME_HERE'
my_base_uuid = 'YOUR_BASE_UUID_HERE'
single = base.get_column_by_name(my_base_name, my_col_name)
options = []
for opt in single['data']['options']:
options.append({'id':opt['id'],'textColor':'#FFFFFF','color':'#C2C2C2'})
url = "https://cloud.seatable.io/dtable-server/api/v1/dtables/" + my_base_uuid + "/column-options/"
payload = {
"table_name": my_base_name,
"column": my_col_name,
"options": options
headers = {
"accept": "application/json",
"content-type": "application/json",
"authorization": "Bearer " + base.jwt_token
response = requests.put(url, json=payload, headers=headers)
print(response.text)
Thank you very much.
But as I have the free plan I don’t have the colour settings option. Could you confirm it, please?
Correct, as it says in the article: available with Enterprise.
