Hello everyone,
I have a question. So I have Seatable running on my server and nginx in front as a reverse proxy.
I was wondering if it’s possible to use the same instance with 2 different domains?
I know I can just duplicate the nginx config and point it to the docker instance but I also know that there are some configs in Seatable which require you to specify the domain.
Would that work?
Thank you in advance.
Cheers
