ratze
December 12, 2022, 3:07pm
#1
Hi everyone!
I would like to connect my self hosted SeaTable instance with my n8n automation instance.
But when I configure it and change some rows I do not seeany connections to the n8n server and see and “Invalid” flag behind the webhook URL in SeaTable webhook gui.
Where can I find the SeaTable logs regarding the webhooks to check what is happening there? Does anyone has experience with SeaTable and n8n?
Thanks in advance for your help.
AkDk7
December 12, 2022, 4:06pm
#2
Hi @ratze .
I haven’t tried to connect it by webhook.
There are to Plugins in n8n which you can use.
Have you tried these?
ratze
December 13, 2022, 5:37pm
#3
I tried the opposite of it. I wanted to use the SeaTable WebHook functionality.
But it doesn’t worked.
ratze
December 13, 2022, 5:38pm
#4
I found the problem. I had to configure the webhook in N8N as a POST webhook. Not a GET webhook.
Now it works fine.
system
Closed
December 15, 2022, 5:39pm
#5
