A Barcode/QR Code generator in the designer page would be a great tool.
Thanks for the request. We certainly will consider that.
Talking about QR code, I just would like to take the chance to add that, just so you know, the SeaTable form has a QR/Barcode reader feature on text columns when you open the form page on a mobile device.
The page design plugin is the wrong place for a barcode/QR code generator.
When we add barcodes/QR codes, we’ll add a separate column for barcodes/QR codes and add a button function to generate a barcode/QR code. The content of the column can then used in the page design plugin.
Hello, very interesting how do you generate the code?
Actually, I think a new column type is not needed. We had written a script to generate barcode/QR code into an image column for a customer.
We can upload the script in the next week. You can modify the script to meet your need, or use any barcode style you want.
Thank you for the answer. Sounds intersting. Where can i download the script?
You can find the script at: seatable-scripts/generate_barcode.py at master · seatable/seatable-scripts · GitHub
