Hi all,
Is it possible to set a column to be fixed? By this I mean that it is permanently visible, even if you scroll far to the right in a large table.
Thanks in advance!
Hi all,
Thanks in advance!
Just go to the line that seperates your row id from your first column and slide it to the right
Oh wow, simple!
Thanks!
Looking into the manual helps:
